What happens if I set two Internet Sources as Priority 1? I have a B One 5G with Starlink and Cellular as sources.
If you have multiple links active at the same time (like in your case all the priority one links), then what happens is governed by the outbound policy. By default I believe it will use the lowest latency algorithm. You can set that under Advanced->Outbound Policy.
If all the priority one links are down, then it will activate the priority 2 links and so on… And there again the outbound policies will be applied to the priority 2 links if there are multiple active at the same time.
