Actually, I would like to see an example of limiting all outbound connections except those to a specific domain or set of domains (or IP addresses). An example of where this would be useful is using “smart” IoT devices based on the Tuya OS. (Smart plugs, smart appliances, etc.). All of these devices normally have commands relayed to/from them via Tuya’s servers, so there’s no reason they should ever contact anything else on the Internet. Honeywell smart thermostats are similar - all communication to/from them is via Honeywell’s servers. So it would be nice to set up firewall rules so that if these devices did in fact acquire malware, the malware would be blocked from communicating with anything else on the Internet except the manufacturer’s servers.
In the original example, if the pattern was just simply “foobar”, would that function the same as foobar? Or would using just “foobar” only be an exact match?
It will match with foobar only. Anyway, this is not a valid domain rule. You should enter foobar.com to match with *.foobar.com or foobar.* to match any host with a name having the domain name in the middle.
