Set up eSIM on POTS Adapter
I’m having difficulty setting up the eSIM on our new POTS adapters. I gave the imei to our provider (VZW) and they have reported it is active but in the inControl dashboard, it’s still showing peplink/tmobile as the provider. Obvi we’re getting good signal since we’re able to access the configurations on inControl. However, when I go to device tools for esim installation, and select input manually, VZW doesn’t seem to know what the activation code is supposed to be. I need to solve this part before moving to the console configuration in the remote admin. One step at a time. If you reply, please be super detailed.
@Neil_Brecher ,
Could you please create a support ticket so that the Support team can assist you further?
For this type of issue, it would be easier to troubleshoot through a support ticket, as we would need more details about the errors you are encountering. This will allow the Support team to investigate the issue more effectively.
The activation code is the QR code (decoded to what’s called an LPA string). Verizon should be able to provide this to you.
We have the default QR code on our support side for a different use case, but it should be the same: https://support.llamanetworks.com/hc/en-us/articles/54905963261843-How-to-Find-and-Install-Your-Switchboard-eSIM-on-iPhone-Pixel-Samsung-and-Other-Android-Devices. Scroll down to section 3 and there is a Verizon QR Code there to try.
You also should make sure that, after installation, your eSIM is set to SIM priority 1 so it’s used initially on boot up.
