hello I have a dedicated device por torrents and I’d like to set the QoS priority for that device to the lowest. id also like to set my roku box and ps4 to the highest.
how do i do this? I don’t see any options in application control to set priority to a mac access or ip address.
thanks for the help
-Andres
Correct it does it by protocol/port based QoS. You should be able to look up what ports the roku box and ps4 use pretty easily and create customer QoS rules for these (allows you to define the ports) but torrents usually use random ports every time and this may not be possible to setup QoS for that traffic.
