I have found out when using my Surf Mini in a campground, others are able to use my surf connection. I’m afraid my security may be compromised. Can others see my info ? Can I add a password ? How ? Thanks, Charlie
You can enhance the security by:
- Hide the broadcast of your SSID (This will require for devices connecting to it to manually type in the SSID/Password)
or
- Create a password for your Surf Mini as opposed to leaving it open. You will need to login to your surf mini and you can assign a password to the SSID that the surf is broadcasting. See image below for reference.
-Change Authentication from open to WPA/WPA2 personal and create your desired password
I tried that and now they are asking for a user name and password to even connect to 192.168.20.1 I tried my password and name from this site but they don’t accept that and now I can’t connect with that url. ?? I never used login info there before.
Try the following username and password:
Username: admin
Password: pep888
If still unable to login please create a support ticket and a member of our support team will be able to assist you.
http://cs.peplink.com/contact/support/
That seems to have done the trick. THANKS
