Secure API Integration for DIEP Flap Surgery Patient Data over Peplink Network
Hello everyone,
We are currently working on a healthcare-related use case where we need to securely manage and transmit DIEP flap breast reconstruction surgery patient data across distributed systems.
Our goal is to build an API-based integration that allows authorized systems to access patient records in real time while ensuring strict data privacy and security. Since Peplink devices are widely used for reliable and secure networking, we are exploring how they can support this type of sensitive data workflow.
Specifically, we would like to understand:
  1. Can Peplink routers or SD-WAN solutions be configured to securely handle healthcare APIs and encrypted patient data transmission?
  2. Are there best practices for setting up VPNs, firewalls, or segmentation for medical data environments?
  3. Does Peplink provide any built-in features that help ensure compliance with healthcare data security standards?
  4. How can we optimize network performance while maintaining high-level encryption and security?
Any guidance, real-world examples, or recommended configurations would be greatly appreciated.
Hello @Rixcy_shah ,
It would be best if we could get you talking with an experienced, certified Peplink Partner in your region.
Please review the options here, or email Peplink for a direct introduction to an experienced professional.
https://www.peplink.com/buy/peplink-certified-partners/
An experienced Certified Peplink Partner will be able to help you with all four of your requirements.
Have a good weekend,
Marcus :slight_smile:
PS, if you’re stuck, you can PM me directly.
We are well versed in API both ic2/device level apis and have done numerous custom projects.
We are located in Decatur, TX, USA, Where are you locate?
Peplink devices handle encrypted tunnels and API traffic fine, but healthcare compliance needs careful segmentation and firewall rules. For the actual API integration and data sync, I used custom software development london from Red Eagle Tech on a similar project, and they sorted out the encryption and performance without issues. A certified partner plus that approach should cover your four requirements.
