Environment
- A government-owned and controlled corporation based in Asia Pacific.
- To take lead in exploration, development, and production of the country’s oil, gas, and coal resources.
- Currently using an ISP connection for HQ to site connectivity.
Requirements
- Introduce a reliable cellular router that can utilize multiple WAN connections namely their 2 existing ISP (wired) connections and also 1 SIM card for cellular LTE.
- Having the ability to bond bandwidths or failover seamlessly should the signal be weak.
- As the data transmitted is confidential, the connection must be through a VPN.
- Deploy a Balance 380X at the mobile HQ.
- This enterprise-grade router can support up to 500 users at the HQ, providing up to 3 Gbps of throughput.
- The added support of up to 100 PepVPN peers gives added security within their infrastructure.
- The MAX HD2 will be used at all 3 sub-branches.
- This has the ability to use two different cellular connections from its embedded modems and SIM slots if needed, giving an ultimate edge for providing Bandwidth Bonding or Hot Failover.
- The MAX HD2 supports 4x GE LAN with the ability to power the devices with its supported PoE output functionality. Ultimately simplifying the setup for your external LAN devices.
- By utilizing InControl 2, configuring, and controlling your Peplink devices remotely has never been so easy. As the data is highly confidential, this would be self-hosted by the end-user (ICVA).
Devices deployed
- Balance 380X
- MAX HD2
- InControl 2 (ICVA)
