I recently installed a peplink balance SDX to replace my balance 380 that died out of the blue. The issue I am facing right now is whenever multiple WANs are in use and downloading (I have a total of 3 at the moment) the overall download throughput becomes less than with one WAN in use.
For example, I run a speed test using WAN 1 and I get 450mbps, I run a speed test with WAN 2 and I get 450mbps.
PC 1 is using WAN 1 through the outbound policy enforce, testing a file download it achieves the same result as I got for the speed test with WAN 1.
PC 2 is using WAN 2 through the outbound policy enforce, testing a file download it also achieves the same result as I got for the speed test with WAN 2.
If PC 1 and PC 2 download at the same time, overall download throughput is less than 450 combined, WAN 1 caps at 150-200, WAN 2 caps at 80-90. If I stop the download on one device than the throughput returns to normal for the device that is currently downloading.
The same issue arises when using the Weighted outbound policy on a single PC. So when one PC is using weighted balance for both WAN 1 and WAN 2 overall download speed is less than when just using the Enforce policy with a single WAN.
I did not have this issue with the Balance 380 and from my understanding the SDX should have 12 times the throughput of the Balance 380.
Things I have already tried:
- Changing the port speed of all WAN/LAN ports from Auto to 1Gbps full duplex.
- Trying different combination of WAN ports and WAN selection on outbound policy.
- Enabling Speedfusion/Disabling (no difference). (Did not have this active with my Balance 380 so I thought it might be affecting it)
- Enabling/Disabling In Control (Also did not have this active with my balance 380)
Also I have eliminated my home network as a possible cause. Connected all devices directly to the SDX router for testing.
Would appreciate any support.
Edit: I went ahead and created a ticket with support, will update this thread if a solution is found.
