SDX Pro - Random Reboots
Hi all,
Unfortunately we’ve experienced two random reboots on an SDX Pro running 8.5.1 build 5955.
The reboots were ~17 days apart.
The SDX has two power supplies on separate UPS in a climate-controlled IT room - and no other rack equipment is experiencing any issues.
I’ve submitted a diagnostic log to Peplink support - but that was over a week ago and no feedback yet.
The event log doesn’t show much, just the “Started up (8.5.1 build 5955)” entry after the unexpected reboot.
Any ideas of anything to check? Any configuration settings that might be involved?
Thanks all!
@Matt_Ross: Minor suggestion – post the ticket number in this thread.
Good call thanks @Rick-DC !
Ticket # 25010599
We had unexplainable reboots on one of our EPXs, and determined it was a faulty 4x SFP+ FlexModule.
Hi @JasonHilton,
That’s interesting… We do have the 4xSFP+ FlexModule installed as we use DAC cables to uplink to the switch.
How did you end up determining it was the FlexModule? Trial and error? Or did anything show up in the logs? (still waiting for Peplink support to respond to my ticket with the diagnostic logs)
Thanks for sharing!
There wasn’t anything conclusive in the logs.
We suspected the FlexModule from the beginning as the only change we made prior to the reboots was adding a 3rd fiber link to it. The reboots started getting more frequent until we removed (and then later replaced) the module.
We had this issue on 8.5.0
Peplink confirmed, that there was an firmware bug (something with qos)
Thanks @Leopold_Strobl for sharing!
We’re on the latest 8.5.1 firmware and don’t have any QoS settings configured (to my knowledge).
Unfortunately it just happened for a THIRD time.
This ticket has been open for over two weeks - and still no resolution (or root cause) from Peplink Support.
Is support really this bad?
Their latest response was to expect a delay due to Chinese New Year.
This isn’t enterprise-level support.
@Matt_Ross found the ticket, let us look into that and get back to you soon.
Hi everyone,
Just wanted to share the update here for anyone else that comes across this issue/post.
Peplink support says they identified the problem as a “CPU lockup issue due to driver related issues.”
They provided a custom firmware release to patch: Firmware 8.5.1s053 build 5992.
We’ve been running this for ~11 days and it’s been stable. But the random reboots were happening over longer duration eg. 17 days - so we’ll see if this holds.
Support advised this fix will be included in version 8.5.2 which has an ETA of ~30 days.
Thanks for this. We’re seeing some random instabilities with the BR1 Mini 5G lately, hopefully it’s a similar issue that will be fixed in 8.5.2.
Did you keep experiencing issues? I run quite a few SDX units, and am curious if you had any resolution.
Hi @Maxwell_Paine
Since running the special hotfix release: 8.5.1s053 build 5992 - we have not seen any restart issues with our SDX Pros.
Support said this fix would be part of 8.5.2 release - which we have not tried yet (still in beta).
Reviewing the release notes, I see this custom firmware being referenced to resolve a “system stability issue” - but it says it’s specific to the Balance 310 5G and BR1 Mini 5G (not referencing the SDX Pro where we experienced the issue).
@WeiMing - Could you confirm if issue 32014 in the release notes of 8.5.2 is also the fix for SDX Pro as well? (not just Balance 310).
@Matt_Ross you are right, the issue found on your SDX Pro was fixed with the reference #33443.
As both fixes (#32014 & #33443) are related system stability issue, we have updated the release notes (8.5.2 RC 2) with the related models.
