My client has SDX PRO setup in high availability mode and they want to authenticate some user to access using windows Radius server.
I configured Windows Radius server and do the setting in the SDX pro also but problem peplink cannot when i using vrrp IP in the radius server user cannot be able to login but when i changed the IP to the master device user immediately login.
can someone to explain why peplink not authenticate with VRRP IP to radius.
