Hi Support,
I deployed LACP but select port show the " Link Aggregation is not supported by the selected port(s)" , what is mean ?
Regard ,
Bit.
Hi Support,
Regard ,
Bit.
@bit.gao ,
For SDX , you can only enable LACP for the below ports :
2 x Ethernet WAN (WAN as LAN ports)
Expansion Module with 8x GE PoE ports
EXM-8C (As LAN ports)
2 x 10G SFP+ (As LAN ports)
Expansion Module with 4 x Fiber
EXM-4F (As LAN ports)
Hi Sir,
About 1 & 3 , that what mean ?
Regard,
Bit.
LACP only can be configure when the ports are configure as LAN ports.
Example :
