Hi Is there any official list witch module works with SDX ? If not could you advise what you used ?
There really isn’t one. See this thread:
Max thanks i use fs modules and work fine for me, if you want i can share with you models
Sure, please share with me the FS SFP SKU that worked for you in the SDX onboard SFP ports (NOT the expansion module). I would be intrigued to know.
yes, which FS modules work for you? there are 20+ different firmwares on them, would be good.
as has been said hundreds of times from various customers/partners, Peplink, give us a list and proper SFP requirements so we don’t have to guess. it’s been YEARS since this was first asked.
Hi Modules like bellow:
FS SFP-10G-T100 FS SFP-10G-T-30 FS SFP-10GSR-85
So are you saying that you’ve tested each of those models and they all work?
Which firmware load did you request when ordering? Cisco, or another one?
Christopher I have feel that this is court hearing.
I used generic but from other guys know that Cisco also should work but I didn’t test I used only generic. For Cisco I used for testing also but the same module work and 2nd dose not
haha sorry. the issue is that Peplink simply refuses to publish compatibility information so im trying to see which ones you had success with so i can add those to my list ![]()
i have also hp modules then test this also but this fs looks very good, i also test a replacment of cisco cml glc-te-cml and this module works and 2nd one dosent i don’t know if peplink issue or modules will test on next instalation for fiber from cml glc-sx mmd work between modules(one switch one sdx)but on short lead 0,5 m. General is not so bad if you ask the question:)
Does this link at 1G or 10G?
Sorry didnt chcek what was showed on dashboard
