Hey,
Is there a list of compatible direct attach SFP+ 10G cables between the SDX router and SD-48 switch?
Something like - https://www.fs.com/de-en/products/21269.html?attribute=8720&id=2376383
Matt
Hey,
Matt
Not a busy topic… I tested the link cable above, with the FS firmware, and connected at 10Gb/s without issue between a SDX and SD-48 switch (and also a netgear switch with a SFP+ port).
I used https://[router-ip]/cgi-bin/MANGA/support.cgi to show the connected port speeds.
I hope this helps.
