SD-SWITCHES: Management LAN concept: VLAN ID = 1 <> untagged LAN
Dear forum,
I really do not understand the VLAN concept Peplink has introduced for management LAN on the new SD SWITCHES in comparison to the routers (e.g. balance one/two). Maybe you can help me with an explanation?
  1. Why do the SD SWITCHEs only have a VLAN1 (ID=1) and not an untagged LAN (ID= NONE (=0))?
  2. Why can’t I add the SWITCHES in Incontrol2 to the untagged LAN of the routers? But can add the routers to the SD SWITCH Management LAN (VLAN1)?
  3. Should I add the routers to the VLAN1 of the SWITCHES? What would happen, if I would do so? What, if I would remove the untagged LAN (ID=0) assignment to the routers afterwards?
Some screenshots toi explain further details:
Any help will be very much appreciated. Thanks in advance!
Noone having any idea? :pensive:
ive had this question for years,
Im absolutely dumbfounded about this, it makes no sense and causes all sorts of trouble, fortigates just do not like vlan 1 as untagged and drop all traffic.
Not to mention some netgear switches come preconfigured with vlans 1-10 being unable to be changed or modified, this just breaks the whole thing.
the only solution ive found is to use a small managed cisco switch, then have that bridge vlan 1 and untagged, and that solved my connection problems with fortigates and other hardware but i mean cmon guys , this shouldn’t even be a thing.
I agree that this is confusingly done, and looks odd in IC2 with the seperate balance vs SD-SWITCH options.
