SD-Switch: VLAN / IGMP Snooping configuration
can someone please help me with some questions about the configuration of VLANs and IGMP Snooping for Peplink SD Switches?
Would you recommend to set a specific IP address for the switch for each VLAN?
Or would you leave the field empty, instead?
Screenshot:
Setting such a VLAN specific IP address is leading to a specific IGMP Snooping querier IP address other than 192.168.1.254.
See screenshot (first row: i set only a specific IP address for the untagged VLAN, but not for the others):
Or doesn’t it make any difference, to what I set the Querier addresses (just leave them on default 192.168.1.254, even if this is different than the VLANs IP range?).
I would highly appreciate any help!
@sitloongs : can you maybe please help me on this enquiry as I did not get any reply, yet?
Setting IP address is necessary when using multiple switches. The switch with the lowest IP number becomes the querier for that vlan.
Thank you very much. This worked fine!
:wink:
PS: Does anyone now the function of the Subnet Mask (see first screenshot in initial post)? As it is only going down to /30 and not /32 it seems not be used to define the IP-Address in detail?
What’s the usecase of a /31 or /32 IP on a interface that is designed to communicate with others?
Hello.
quick answer:
All 128 of the Possible /31 Network
All 64 of the Possible /30 Network
Thanks Marcelo.
Sorry, but I do not understand why I should restrict this instead of /24?
Hi…
No… I just try explain for you… Why we use /31 and try to not use /30.
/31 is two IPs, although one is technically a broadcast address when you use a /31 you assign an IP to two sperate hosts.
/32 is hard to see the value of in this circumstance.
