Dear All,
Who can advise me which SFP modules (Mini GBIC) are compatible with Peplink SD switches?
I plan to use multimode patchcords (max distance is < 500m).
Thanks in advance.
Dear All,
Thanks in advance.
We have tested with the UBNT Fiber Multi-Mode SFP 10G Mode: 10GBASE-SR SFP+ and it worked on our switches.
Hello and thank you for your answer.
We normally ordered the right references. We will test on 24 and 48 port switches.
Best regards
Hello everyone. Does anybody know if this module works with the 8 port and 24 port switch?
Optical Transceivers
1000BASE-SX and 2G Fibre Channel (2GFC) 500m Industrial Temperature SFP Optical Transceiver
FTLF8519P3BTL
https://www.finisar.com/optical-transceivers/ftlf8519p3btl
https://www.finisar.com/sites/default/files/downloads/finisar_ftlf8519p3byl_2.125g_rohs_compliant_short_wavelength_sfp_transceiver_product_specification_revd2.pdf
