We really need to be able to configure a port to have a custom untagged vlan while also having some (but not all) tagged vlans on the port.
this can be done on the switch itself, but not in IC2.
Hey Bryn,
This can be done if a port is a trunk port, see below:
Or are you requesting something else?
We need to be able to have (using your example vlans) say vlan 101 as the untagged vlan on the port, and vlan 31 tagged.
doable on the switch locally, but oddly enough not in IC2.
Ahh - now I get it.
That would indeed be useful - not something we’d usually use, but I can see the use case.
+1 from here!!
