I would like to request for port security on the SD Switch.
This is to prevent unauthorized access to the network by physical connecting ethernet cable to the network port.
MAC Address restriction with a few MAC address
Sticky port
The MAC address is recorded for the 1st device that is connected to it.
Thanks.
they do support 802.1x, on the device itself (not configured from IC2)
I’d also like to upvote this, basic mac-port binding would be helpful for those who don’t have a dot1x infrastructure set up.
TK_Liew
4
We do support Ingress ACL.
Please ensure your SD Switch is running latest firmware version.
Hope this helps.
Great, I was sticking too much to IC2 and did not see this.
I will try it out.
Thanks.
