Dear forum,
i have connected 2 x Peplink sd 24 switches using each switch‘s port 24 with 2 of my Balance router‘s LAN ports. To enhance fail-safe reliability, i also connected both switches using glass fibre channel via port 25 and turned on Loop protection (active mode) for both.
Is that correct? Or do I have to configure one of the switches to be in passive mode?
Did not understood the difference in detail acc. To the manual….
Kind regards
Does noone has any comment on this topic?
@sitloongs : can you maybe please help me further?
I looked into this in more detail and wanted to share the correct setup and my learning:
Short answer:
- I should NOT rely on Loop Protection (Active) for switch-to-switch redundancy
- STP/RSTP must be used as the primary loop prevention mechanism
- Loop Protection is only a fallback safety feature
My setup:
- 2x Peplink SD Switches
- both connected to the Balance router (2 separate LAN ports)
- additional fiber link between the switches
This creates a Layer2 loop by design, so it must be handled properly.
Correct approach:
- Enable RSTP on all switches (default is fine)
- Keep all inter-switch and router uplinks as Trunk ports
- Do NOT use Loop Protection Active on these links
- Optionally use Loop Protection Passive as a safeguard
Reason:
- STP/RSTP is designed exactly for this topology and will block one path cleanly
- Loop Protection Active sends probe frames and may falsely detect loops or shut down ports
- In redundant topologies, Active mode can interfere with STP and cause instability
When Active mode makes sense:
- On “unsafe” access scenarios (e.g. patch panels, unknown cabling)
- NOT on controlled uplinks between switches or to the router
- Powerline Distributing Switch
Conclusion:
- The topology itself is correct
- Loop handling should be done by RSTP, not Active Loop Protection
- Best practice:
- Uplinks: RSTP enabled + Loop Protection Passive (optional)
- No Active mode on these links
Hope this helps others as well.
Regards
