My network consists on 1x Balance 210 (FW 8.2.0) and 2x SD Switch Rugged 24 (FW 1.3.0).
Switch A Port 1 is connected to the Balance 210 on LAN 1
Switch B Port 1 is connected to the Balance 210 on LAN 2
There are 4 VLANs - Untagged, VLAN10, VLAN20, VLAN30
Inter VLAN routing is configured on the Balance 210 (Network - LAN - Network Settings - Inter-VLAN routing)
Balance 210 Untagged VLAN IP = 192.168.0.1
Balance 210 VLAN 10 IP = 192.168.10.1
Balance 210 VLAN 20 IP = 192.168.20.1
Balance 210 VLAN 30 IP = 192.168.30.1
Switch A Untagged VLAN IP = 192.168.0.2
Switch B Untagged VLAN IP = 192.168.0.3
My understanding is that;
-Data from a device on VLAN10 on Switch A being sent to a device on VLAN20 on Switch A would be sent up the trunk cable connection between Switch A Port 1 and Balance 210 LAN 1 where it will be routed from VLAN10 to VLAN20 and then sent back down the same cable to Switch A where it will be passed onto the device on VLAN20.
-Data from a device on VLAN10 on Switch A being sent to a device on VLAN20 on Switch B would be sent up the trunk cable connection between Switch A Port 1 and the Balance 210 LAN1 where it will be routed from VLAN10 to VLAN20 and then sent for the trunk cable to Switch B on Balance 210 LAN2 where it will be passed onto the device on VLAN20.
My questions are this:
On the Switch under Configure - Network Settings - LAN - Inter-VLAN Routing, if this is configured, can data be routed between VLANS on the switch without forwarding the data onto the Balance 210 ? If the device does not exist in a VLAN on that switch is the default action to pass this up to the Balance 210 because it cannot find the destination MAC in its internal routing table? Would I need to enter a value in the Optional IP address field and/or enter a value for Inter-Vlan Routing IP address?
Ultimately I would like to reduce the traffic passing through the Balance 210 as much as possible so that only data that is going external from the network is passed onto it. Any high bandwidth/video data should be passed between the switches and/or VLANS without going through the Balance 210. I would therefore like to utilise the SFP+ ports between the 2 SD Switches and use a DAC cable to connect them. Will this cause a loop(triangle)? Will the routing aspect of the switches realise that it is one less hop to go via the SFP+ rather than Port1 and through the balance 210? Is there any special configuration that needs to happen to allow this to happen.
Thanks for your help
Tom
