Is there a way to configure high-availability between two 24port SD-switches?
Best Regards,
George
Best Regards,
George
We don’t have the same type of HA setup on the switches but you can take advantage of Spanning Tree Protocol. The switch with the lowest priority will be the root/master while a switch with a higher priority will be in standby/slave.
This one would be acting as the root or master switch:
This one would be in standby or acting as the slave:
Thank you for the input
Best Regards,
George
