After configuring the port switch on the SD Switch, I downloaded the configuration file.
The configuration was added to the IC2 for bulk configuration.
When apply to a switch, the port name is correct but the port type was not configured correctly.
All the port type became trunk when it was supposed to be Access with VLAN number.
The port setting was also not correctly imported:
After import all ports were enabled while some of the ports were supposed to be Disabled.
Is there a way to manage the switch port configuration from IC2 ?
