Hi.
We are looking into SD Switch 8 ports and powering it up with DC 24V via terminal blocks. Will PoE work? How much PoE budget will there be?
Kind regards
Hi.
Kind regards
Hi Anze,
to have PoE output you need to have at least 48V DC input. You can have up to supports up to 240W (depends on power supply).
More details you can find in the datasheet.
