My ISP is not the most reliable and about once a week I need to reset my GSM device to get my Data services functioning again. While in the lab it is not an issue, this will not be ideal once they are deployed in geographically dispersed locations. I would like to know if it would be possible to have a schedule restart option in the firmware for the Pepwave Max BR1 modems. That way I could schedule the weekly restart to try and preempt the weekly hangup.
We have cellular WAN reset mechanism to handle such case so that user don’t need to power cycle the unit to reconnect to ISP. May I know what is your firmware version?
The version I’m using is 6.1.1 build 1524
Please upgrade to v6.1.2 to confirm whether will help on your problem.
