Would be nice to be able to schedule a device reboot to occur with a snapshotted configuration at a particular time in the future – the feature is to enable making remote configuration changes which might impact device availability while maintaining the highest probability of recovery if things don’t go as expected …
Something to enable below pattern:
schedule the device to reboot with the current configuration (saved at the time the reload command is run) in 10 minutes
> reload in 10
go into web ui and make a configuration change/changes, hit apply
if you can still access the device and cli and are happy with the change, then run the below command before 10 minutes are up
> cancel reload
