Hi. I’ve got a Peplink Balance 20 and had it running with two lines. One from an line-of-sight ISP and the other Starlink. The Balance 20 is connected to an Eero 6 Pro network set in bridge mode. This give me speeds of 8-12MBPS but when I connect the Starlink straight to the Eero wifi bypassing the Balance 20 I get between 75 and 150 MBPS. I even turned off my secondary line and don’t have any custom rules added. Help most welcome.
I suspect this is related to a known incompatibility. If you put a switch between the WAN of the B20X and the Starlink I expect you’ll see the speed comes back.
There is a thread here somewhere about it but I can’tf it.
