Rubber Foot Pad set for Peplink SD Switch Rugged (old switch) still available?
HI,
do you know if the “Rubber Foot Pad set” (4 rubber adhesive feet) is still available as spare part for the old Peplink 8-Port SD Switch Rugged (PSW-8-240W-RUG)? I could not found a spare part/order number for them.
Is the Ear Mounts/DIN Rail Mount kit for 8-port SD Switch (ACW-DIN-PSW8) also still available?
If yes, can anyone of our distributors here in the forum maybe sent me a PM with a quote for shipping them to Germany?
I’ve run into this a few times. The easier thing is to get thin rubber furniture pads, or, buy the easily-found Cisco ones (https://www.ebay.com/itm/163850009379).
Moin,
Tip from Germany:
Search for Self-adhesive rubber feet, 346 rubber studs for glass panels
by the “big river” or wait for selling at Aldi or Netto :slight_smile:
Thank you all!
Fortunately, our Peplink distributor still had a set of these required rubber feet and sent them to me. :star_struck:
Note: However, Peplink support could not provide me with a corresponding spare part number.
