@Vitaly , @MartinLangmaid
Do allow me to answer your question first. If you are referring to route specific application via Peplink SpeedFusion Cloud (SFC) then the SpeedFusion Cloud —> Optimize Cloud Application page will best use here.
Do allow me to explain the DPI steering , SaaS Application and the Optimize Cloud Application for SFC.
1. DPI Steering (This is only work between SpeedFusion sub Tunnels) - Local WebAdmin
Example :
----Traffic Direction----->>>> Site A ----SF—> Site B ------> Internet.
A ------------------------Default Tunnel ---------------------B (All Traffic)
A ------------Sub Tunnel Smoothing enabled -----------B (Zoom , etc)
- Use outbound policy to defined which application to use the smoothing sub tunnel.
- Send all Traffics required
- DPI engine will recognize the type of traffic after several packets passing through, so the first few packets may be routed to the default tunnel, but when DPI successfully recognized the traffic, it will be steered to the correct sub-tunnel while keeping the session intact, without any interruption.
- WebAdmin will be improve for future firmware to reduce the confusion how the DPI Steering will work.
2. Optimize Cloud Application for SFC - Local WebAdmin
- This will forward supported applications using SpeedFusion Cloud (SFC) connections.
- This is using the SaaS application IP addresses DB that maintained by Peplink.
- More SaaS applications will be added for the coming firmware.
3. SaaS application rules via IC2.
- This allow forward supported application via WAN direct or SpeedFusion tunnel.
