Hi, I tried the Router Utility and logged in with my user account and could still switch off wifi. Normally it should be locked with user rights - I think?
Router is B30 Pro V8.0
You are saying you setup a non-admin log-in and it was specifically permissioned to NOT allow changing WiFi settings to be turned off and you can log-in and change WiFi settings with that user?
On my router I set under admin settings a read only user. This user and password I use in the router utility.
