Does anyone know if any of the routers, especially the Peplink MAX BR1 Pro 5G , will work with a Telcel SIM card in Mexico? Thank you.
@Reynaldo_Lucio Someone for you at the door ![]()
Yes, as @Venn has tacitly suggested, your best source will be a MX Peplink Partner. If the source suggested does not work and you need some additional help send me a PM and I may be able to point you to a couple of folks who may be able to help. There is no substitute for “local expertise.” :<)
Hi @Bruce_Niss !
Yes, it should work with both 5GH and 5GD versions.
However, Telcel has some cellular plans restricted to only work with Telcel modems. So, you need to get a sim with no IMEI limitations plan.
Please let me know if we can be of further assietance… we are the Distributor in Mexico (www.ctonet.mx)
