We are pleased to announce that Router Firmware 8.6.2 Beta 1 is now available.
38011 [Beta 1] [Wi-Fi] Disabled Wi-Fi DFS channels in the United States, Canada and Japan.
Lai, does this mean “disabled by default” or “permanently disabled” ? Ideally Peplink devices would not use DFS by default and also stick to only 1,6,11 on 2.4GHz. However, a user SHOULD have the ability to use DFS in areas where it’s prudent.
Wow! Great amount of bugs fixed!
Congratulations to the Peplink dev team! ![]()
Works on our B One.
Could you also add a time zone for Saskatchewan too? Currently you have
but Saskatchewan hasn’t been on central time with the US since 1972, it doesn’t shift for DST.
The release note for 38011 has been updated. This change applies to Wi-Fi WAN only, and DFS channels are not available there (it’s not a configurable option).
For now you can use “Central America” which is the correct timezone (UTC-06:00 with no DST), we will update the labeling on the menu to reflect that in coming betas. Thanks!
