Router Firmware 8.6.0 Beta 2
@Jonathan_Pitts , Could you help us with a support ticket ?
@oddfugl , Do you mean MBX as SC and managing WiFi Synergized WAN for other device ? If yes , this is supported.
@sitloongs , No, WiFi AP. See from release notes:
The MBX is not mentioned.
That fixed it! Thanks!
@oddfugl ,
Thank you for spotting the missing MBX model in the supported feature list for Reference ID: 33106.
This was a typo mistake. MBX is supported as the Synergy Controller to manage the Wi-Fi 6 Synergized devices.
Edited 28/5/2026 (beta3 released notes added the missing MBX model)
@Rafferty_Woentono , if there is a requirement to be on 8.5.4 for 8.6.0 to work properly, please ensure this is called out in the release notes and that IC2 limits/warns on upgrade from a non-supported version.
That, or the problem is fixed in 8.6.x and we can upgrade from any other version :slight_smile:
@ChristopherSpitler confirmed, 8.5.4 will be a prerequisite for upgrading to 8.6.0 via the web admin. I’ll make sure this is called out appropriately. However, upgrading the firmware via IC2 should not have this issue. Thanks
