another +1 from my side
even for FusionHub it is important, because you never find a route conflict in a meshed network without that.
We deploy routers/firewalls from Cisco, Adtran, Cradlepoint, Palo Alto, Ubiquiti, Edgewater/Ribbon, VeloCloud. Peplink is the first vendor we have encountered that does not have the âshow ip routeâ command or equivalent. Truly baffling.
@Mario_Marquez Iâve read your multiple posts regarding this subject and I have a suggestion you may wish to consider. I, for one, have found Peplink to be a very responsive company that listens to its customers. Indeed, a great many suggestions made in the Forum have found their way into firmware.
If you have a requirement that is not being met by the present FW start a new thread and place it in the âFeature Requestsâ category. In the body of your text provide a link to the recent threads where you have discussed the issue any messages which may be pertinent after conducting a search. Explain what you want and provide a solid use case. Ask for a response. The good folks at Peplink will read it. I have a strong guess that youâll receive an authoritative answer. Peplink responds very well to great ideas.
Just a heads up that we are aware of this need and the team is looking at some possible options. We will get back to this. Thanks.
We will try to catch up on this feature in 8.3.1. Probably the routing table can be shown via CLI.
This feature was first requested in 2016, some 7 and a half years ago, and has been asked for many, many times since. Is it still not possible? On the UBR-LTE it does not seem to be so.
Amazing.
+1
We also would love this even if it only was for non-sdwan routes.
In case you may have missed it, there is an option on InControl to access the CLI at your convenience.
CLI Command is support ip-route-show for those who havenât used it before.
Iâm on 8.5.0 and cannot run âip route showâ or âip-route-showâ in any format
I canât find any routing info to be displayed when trying to diagnose my routing issues.
EDIT
Found it.
Web CLI > Support > ip-route-show
Can I use this command on fusionhub through console?
