Route setting for UDMP behind Balance 305
I have the original UDMP behind new BALANCE 305.
NAT on UDMP is disabled and Static Route set, but I still cannt reach defined server thru Inbound Access Services.
Route
  1. ISP thru WIFI / 2. ISP 4G+
    Balance 305
    UDM Pro
    2x Web server + 1x NAS
Balance - 192.168.2.1/24
Static Route Dest. Netw. 192.168.1.0/SubNet 255.255.255.0/Gateway 192.168.2.10
UDM Pro WAN1 - IP 192.168.2.10 / SubNet 255.255.255.0 / Router 192.168.2.1
UDM Pro Lan - 192.168.1.1/26
Can somebody help me a bit?
Many thanks in advance!
Start on your Balance 305. Use the ping tool in the web admin can you ping the target IP in the 192.168.1.0/24 network?
WANs on Balance 305 are WISP and 4G? Do either actually have a public IP that accepts inbound routing?
Yes I have on both WAN public IP. If the accept inbound routing - no idea.
I have tried to connect NAS directly to Balance LAN and route only in Balance to 192.168.2.1/24 and that works.
I cannot ping the internal IPs on 192.168.1.0/24 from web admin, so the problem will be somewhere between Balance and UDM or I guess directly in UDM setting.
Any idea? Should I send some screenshots of my settings?
Hi Martin,
till I have disabled NAT on UDMP I see all equipments behind static route
but still I cannot Ping them.
Can you help me please?
Thanks.
