I have peplink router 1 = 10.10.10.1 and router 2 = 10.10.10.2, I create a Speedfusion VPN between two routers and it shows in status “route conflict” . any help
You are probably using a netmask of 255.255.255.0, which is the common situation. Therefore, they are on the same subnet. I’m betting if you change the second one to something like 10.10.11.1 the problem will go away. Once you do that the router is smart enough to encourage you move the IP addresses of the clients to 10. 10. 11.x also – which is required to avoid overlap.
in this case i can’t change any ip, but i found the solution, it’s One-to-One NAT
OK … there ya go. That’s certainly an alternative.
