Retain WAN Configuration Factory Reset
Hi support,
I would like to request the option to retain WAN configuration when doing the Factory Reset.
We have a case the customer uses the B One 5G in the vessel with Starlink and 5G connection.
If there is a need to factory reset the router and the vessel is out of mobile coverage, Starlink couldn’t be established due to the health check failed on the default parameter.
Thanks!
Regards
You can do this already. Setup the device as you want it, then trigger the service provider default call in the IC2 API and the running config will be used as the factory reset config. but be very careful of course about what settings are included. I would recommend only setting what you really have to to get the device online rather than a full config.
