probably a simple question
How do I manually reset the data counters to zero on the **Pepwave MAX HD2 ****6.2.0 build 2895.
You can just disable the Bandwidth Allowance Monitor, save and apply changes. Then go back and re-enable it with the correct billing cycle start date and data cap, save and apply changes.
