Requirements for load balancing
#1
hello
im thinking of buying the new 4g service in london to add to my existing broadband and then buying a peplink to load balance the two services.
are there any requirements on the services for success – i thought i saw somewhere that both services need to have a static IP adress
many thanks
chris
#2
Hi Chris,
Static IP is not needed if you use Peplink for Outbound Load Balancing.
Hope this help.
#3
Hi
Thanks for the reply
Does outbound load balancing mean when i upload
does this mean i need static IPs for load balacing the downloads
finally will the peplink 20 be sufficient
#4
Yes, Outbound Loadbalancing is set up by default on our devices and this applies to a time when traffic goes out to the outside world.
(Please know that Peplink is a session based load balancer, so when a session is established from LAN to WAN, this session keeps utilizing the same WAN until a new session is created.)
Yes, you would want to have a static IP for Inbound Loadbalancing. Please refer to the following KB article.
Hope this helps.
#5
thanks
i dont fully understand everything. can i check
– will a peplink 20 be sufficient
– i definitely need a static IP on both lines to achieve the load balancing for by internet usage
many thanks
chris
#6
– Hello, you will need a Balance 210 on up to take advantage of the Inbound Load Balancing feature: http://www.peplink.com/knowledgebase/understanding-inbound-load-balancing/
– Balance Series Specifications: http://www.peplink.com/products/balance/model-comparison/
