Request for OBP to using the physical port vrs the port Name
So if you setup a OBP in the IC2 system you have to choose the outbound interface. For most its WAN1 or WAN2, but if you rename WAN1 to “this is outbound port” for the name you now in the OBP have WAN2 and “this is outbound port”
now if you have 100 boxes and each WAN1 port has been rename for each site. your OBP has the option of WAN2 and 100 different port names.
I would like to be able to create a global OBP using the physical interface WAN1 and NOT using the name of the interface.
so use the Physical port for OBP vrs the Name of the port for OBP.
