I plugged in the GPS receiver to my Max BR1 before it was deployed, and have since deployed it in an office on the other side of the state. Is there any way to remove the GPS info from it, so I can manually enter the location of the device?
Just to check do you need the GPS fleet for the final deployment ?
If the final deployment having GPS fleet then the GPS location will be automatically updated after the deployment and this should not cause any issue for the actual GPS locations.
Else if the final deployment doesn’t require GPS, then you can turn off the “GPS Location Tracking Setting” at the IC2 group level settings and this should allow you to set the devices GPS location manually again.
IC2 group level settings:
Device Level settings - GPS location
Perfect. Thanks for the detailed info.
