Is possible Peplink add a route to OpenVPN tunnel VPN connection?
Peplink ( OpenVPN server) LAN 192.168.50.1/24
Third party M2M router1 (remote site 1) LAN 192.168.1.1/24
Third party M2M router2 (remote site 2) LAN 192.168.2.1/24
It can’t to define the static route “gateway” ip address (random vpn client IP).
You can define a DHCP reservation for a remote client. That’s at the bottom of the LAN settings with the latest firmware.
This is definitely the way to go. I’ve done this for a few IoT deployments. Once you pin the OpenVPN client IP via the reservation settings, the Peplink treats it just like any other gateway. It turns a “Remote User” connection effectively into a Site-to-Site link.
