Remote SIM component is incompatible to the firmware, please contact distributor for support.
I bought a “bring your own device” plan from Nomad Internet. After installing the device I was getting 35 mbps per second down and 10 ish mbps up load speeds. As you can see by attached this worked for about 2 hours now there is nothing. And I get this message on my peplink dashboard.
I am using this set up from WaveForm.
Any help would be appreciated.
HI There,
I got same mesage with My B20X Box. any info about this error message ?
I’m only saying this from past experience, but Nomad is quite well known for having unauthorized plans resold from Tablet or other “non-router” style plans. Carrier side throttling is highly likely the cause of your slowdown.
I’m curious what carrier you are using?
If you want to use Verizon we can help.
We “1SimplePhone” are a peplink partner and an Verizon reseller.
We have authorized plans where we match your imei and iccid directly to the plan.
David,
I would encourage you to do a search on Nomad Internet on the internet. You should then be able to arrive at your own conclusion as to why you are experiencing issues.
Good luck!
