Reducing packet loss in SpeedFusion: 2 fibers + Starlink. What would you optimise?
Hi all. I run a Balance 1350 EC with one SpeedFusion Connect tunnel (Johannesburg hub) over two fibre links and one Starlink, Smoothing Medium and FEC Adaptive. My goal is to cut the packet loss on each leg, both uplink and downlink.
What the SpeedFusion statistics show:
  • Starlink: loss in both directions, uplink about 6× the downlink (e.g. 26.6 pkt/s up at 8 Mbps, 4.5 pkt/s down at 20 Mbps). It is steady, not only in bursts, and it grows with load.
  • Both fibre legs: steady small loss on the downlink, clean uplink.
  • Out-of-order is high on all three legs and rises with load.
What I’ve checked:
  • Direct pings outside the tunnel are clean on all links.
  • The dish telemetry looks healthy, and the Starlink port shows no errors.
  • No bandwidth limit on the Starlink side.
  • MTU is 1440 on the fibre ports and 1470 on Starlink. Fragmentation is only about 1.5 pkt/s.
  • I’ve tried a few smoothing and FEC combinations without improvement.
Questions:
  1. What causes per-leg loss inside the tunnel when direct pings on the same link are clean?
  2. How can one minimise the starlink uplink and downlink packet loss? about 5-10 packet loss per second.
  3. Is downlink loss on 2 of the legs a sign of something at the hub or its network? How would one troubleshoot that and how much control do we actually have? Is SpeedFusion Connect versus a self-hosted FusionHub recommended? or vice-versa?
  4. Which profile settings are known to cause the least per-leg loss (MTU, bandwidth, latency cutoff, smoothing and FEC together)?
Thanks!
