I’m using a Peplink MAX BR2 Pro and powering it from a battery, because it is in a mobile solution. Is there any ‘reduced power mode’ in the software, where certain non-essential function are disabled? My assumption is that by disabling WiFi and other connections power consumption should already go down. Anyone that can confirm or deny?
it would be cool to see a minimal services option, mine gets so hot, my balance 310 5g, the rubber pads drift on the bottom of the steel enclosure from the adhesive getting hot.
