Recommended POE injector for MAX HD1 Dome Pro
Hello Peplink aficionados. I have a couple of questions on a project I’m working on. The system will have two HD1 Dome Pro’s and a Balance Two as a hub router. I was considering using two independent POE injectors, one for each dome, in lieu of using the SIM Injector to power both. Is there a recommended POE injector supplier and model that would work well with the MAX HD1 Dome Pro units? I’m looking for something that works off 48 vdc. Also, can I add the two domes to the Balance Two router using LAN ports and VWAN configuration? I plan to use Synergy mode in 8.3 to manage both domes from the Balance Two. The two existing Balance Two WAN ports are going to be assigned to other WAN sources (Starlink Flat HP dishes). Thanks in advance for the advice!
