Reboot Order: SOHO Mk3 and USB Modem
Everything was going fine, I was downloading some stuff over wifi through a Surf SOHO Mk3 connected via USB to a ZTE Mobley. I was averaging 12Mbps, which for us is really good. Then the SSID just disappeared. I went to the router and rebooted it, but now I’m not getting more than 20kbps. I restarted the modem next, and still nothing.
I’m not sure where the problem is or what happened. I didn’t change any settings. Its just like the SSID disappeared and now the connection is crap. So I’m wondering which order I should power everything back on. Modem first, then SOHO? Or the other way around? Or should it make any difference at all?
Just know that you have figured out the problem which is not related to SOHO MK3. Please ignore my PM and ticket will be closed.
Thanks.
