Hello. I have a BR1 Mini which connects PLC based meters to our scada. The scada interrogates the meter through the Pepwave modem however I would also like for the PLC to poll the modem for its GPS location so it can pass it to the scada when it reports.
Any hints on a way to make this work?
Chris
Look at this How to read GPS position direct from LAN using Python
its python but you could port the code to anything really.
Thanks for posting. Looks interesting but I don’t know enough about PLCs to know if it’s applicable. Everything on the PLC is modbus as far as I know but I would need to talk to my PLC guy to know if he can run Python.
No - python code is just an example. Ask him if you can open a raw TCP socket to then read the GPS NEMA sentences.
