RDP into Servers on LAN - Peplink Routers | Port Mapping (Static IP)
How to RDP into 2 servers or multiple devices via RDP port 3389 on the LAN but through 1 single WAN ip (must be static public) mapped to different ports. You can dot his on the cellular network as well as long as you have a public static.
You have to also use : colons then the port number via rdp to login to each.
Example:
