FusionHub Solo on 8.1.1
Transit-Duo Max LTE-A Pro on 8.1.1
Today we had again a Tunnel disconnect. On the TransitDuo the WAN and LTE1 was used, and had no online issues. I only see theses logs in the TransitDuo:
|Feb 25 09:51:07|SpeedFusion: FusionHubVM (FusionHubVM, sn:11D4-BE54-XXXX) connected to MEB-FH (2 - JustBonding)|
|Feb 25 09:51:04|SpeedFusion: Initiated TLSv1.3 connection to x.x.x.x using cipher suite TLS_AES_256_GCM_SHA384|
|Feb 25 09:51:03|SpeedFusion: Initiated TLSv1.3 connection to x.x.x.x using cipher suite TLS_AES_256_GCM_SHA384|
|Feb 25 09:51:02|SpeedFusion: Initiated TLSv1.3 connection to x.x.x.x using cipher suite TLS_AES_256_GCM_SHA384|
|Feb 25 09:50:59|SpeedFusion: FusionHubVM (FusionHubVM, sn:11D4-BE54-XXXX) connected to MEB-FH (1 - Smooth+FEC)|
|Feb 25 09:50:44|SpeedFusion: Initiated TLSv1.3 connection to x.x.x.x using cipher suite TLS_AES_256_GCM_SHA384|
|Feb 25 09:50:43|SpeedFusion: Initiated TLSv1.3 connection to x.x.x.x using cipher suite TLS_AES_256_GCM_SHA384|
|Feb 25 09:50:42|SpeedFusion: Initiated TLSv1.3 connection to x.x.x.x using cipher suite TLS_AES_256_GCM_SHA384|
|Feb 25 09:50:41|SpeedFusion: Initiated TLSv1.3 connection to x.x.x.x using cipher suite TLS_AES_256_GCM_SHA384|
|Feb 25 09:50:36|SpeedFusion: FusionHubVM (FusionHubVM, sn:11D4-BE54-XXXX) disconnected from MEB-FH (2 - JustBonding) (default tunnel to this remote peer is disconnected)|
|Feb 25 09:50:36|SpeedFusion: FusionHubVM (FusionHubVM, sn:11D4-BE54-XXXX) disconnected from MEB-FH (1 - Smooth+FEC) (link failure detected)|
|Feb 24 15:54:19|SpeedFusion: Initiated TLSv1.3 connection to x.x.x.x using cipher suite TLS_AES_256_GCM_SHA384|
|Feb 24 15:54:18|SpeedFusion: Initiated TLSv1.3 connection to x.x.x.x using cipher suite TLS_AES_256_GCM_SHA384|
And on the FusionHub Side:
|Feb 25 09:51:08|SpeedFusion: TransitDuo-1 (TransitDuo-1, sn:2938-FC6E-XXXX) connected to TransitDuo1 (2 - JustSpeed)|
|Feb 25 09:51:06|SpeedFusion: Accepted TLSv1.3 connection from x.x.x.x using cipher suite TLS_AES_256_GCM_SHA384|
|Feb 25 09:51:04|SpeedFusion: Accepted TLSv1.3 connection from x.x.x.x using cipher suite TLS_AES_256_GCM_SHA384|
|Feb 25 09:51:03|SpeedFusion: Accepted TLSv1.3 connection from x.x.x.x using cipher suite TLS_AES_256_GCM_SHA384|
|Feb 25 09:51:00|SpeedFusion: TransitDuo-1 (TransitDuo-1, sn:2938-FC6E-XXXX) connected to TransitDuo1 (1 - Smoothing+FEC)|
|Feb 25 09:50:45|SpeedFusion: Accepted TLSv1.3 connection from x.x.x.x using cipher suite TLS_AES_256_GCM_SHA384|
|Feb 25 09:50:44|SpeedFusion: Accepted TLSv1.3 connection from x.x.x.x using cipher suite TLS_AES_256_GCM_SHA384|
|Feb 25 09:50:43|SpeedFusion: Accepted TLSv1.3 connection from x.x.x.x using cipher suite TLS_AES_256_GCM_SHA384|
|Feb 25 09:50:36|SpeedFusion: TransitDuo-1 (TransitDuo-1, sn:2938-FC6E-XXXX) disconnected from TransitDuo1 (2 - JustSpeed) (default tunnel to this remote peer is disconnected)|
|Feb 25 09:50:36|SpeedFusion: TransitDuo-1 (TransitDuo-1, sn:2938-FC6E-XXXX) disconnected from TransitDuo1 (1 - Smoothing+FEC) (link failure detected)|
|Feb 24 15:54:20|SpeedFusion: Accepted TLSv1.3 connection from x.x.x.x using cipher suite TLS_AES_256_GCM_SHA384|
|Feb 24 15:54:19|SpeedFusion: Accepted TLSv1.3 connection from x.x.x.x using cipher suite TLS_AES_256_GCM_SHA384|
We upgraded form 8.1.0 a while ago.
So, how can we debug this whats actually happening here?
Thx!
Best regards, Martin
