Dear Guys,
How is it possible to setup RADIUS Authentication on Captive Portal for AP One devices ? Is there any user guide for this ?
Dear Guys,
Hi Hootan,
You may use Balance router to manage AP. Then enable Captive Portal on Balance router with Radius Authentication.
It’s not possible without Balance router ? using Incontrol or any other way ?
Hi Hootan,
InControl’s Captive Portal doesn’t support Radius authentication at the moment.
An alternative way, you may use Web Portal (AP > Wireless SSID > Select SSID > Web Portal Login) on individual AP with external Splash page server.
Thanks for your reply,
Is there any configuration guide or case study regarding configuring external splash page ?
Hi Hootan,
You need to host a server and develop a Splash page based Knowledgebase here. Fyi, HTML programming is needed since this involves parameters passing between AP and Splash page.
Hi, does it work only with balance or would it work on a HD4 for example ?
@xsand.be, yes it works with MAX devices.
